1 - 7 of 7 Posts
I would have thought the F17 will have a lot taller 5th gear than the F13 from the Z14XEP so motorway driving will be better as the rpm will be lower for top speed.
I know that is the case on the UK spec'd SRI Corsa C anyway.
Here is what I found
1800 TIGRA IS CLOSE RATIO
3.727 (13.94)
2.136 (7.99)
1.414 (5.29
1.121 (4.19)
0.892 (3.34)
fd 3.74
1400 COMBO WIDE RATIO
3.73 (15.59)
1.96 (8.19)
1.3 (5.43)
0.95 (3.97)
0.76 (3.177)
fd 4.18
Thanks
Ian
It depends what you want? Low rpm at motorway speeds or fast acceleration?
Are you planning to tune the 1.8 for decent power (250+) or leave it stock?
I have the F23 in my Corsa C and Tigra B and about to fit the 3.54:1 final drive to the Tigra as in the Corsa it helps to get the power down faster than the 3.94:1 final drive while also keeping rpm down by almost 1000rpm at 70mph.
I will be doing minimal mods and it works out to about 200 revs extra in fifth gear to have the close ratios and a stronger box . A pair of mild cams that the factory EFI could cope with would be nice and easy to do at the moment .
I think you will find you have a lower rpm for the same top speed with the Tigra B box even with the smaller rolling radius of the Combo's wheels. It will also be better suited to the 1.8 over all.
1 - 7 of 7 Posts
