1 - 6 of 6 Posts
Hi, I've got a 2001 corsa 1.2 petrol and having problems starting it, some times it will start no problem. Then some times when the ignition key is turned on nothing on the dash board comes on but it will turn over.. any advice would be greatly appreciated thanks
Administrator, Trusted Seller
try doing the pedal test
google pedal test
Super Moderator
forget google..........
or
As Liviu said, remove the guage cluster and then check that the plug on the back is fitted correctly and not got the green crusties
1 - 6 of 6 Posts
