Not many would rebuild an engine on one of these Corsa's the cost of parts would be 3-4x what the car is worth in UK, it's been that way for many years now.
A set of new pistons is near on the price of a decent stock Corsa C now.
If engine is that worn out it's just not worth repairing for us in UK. Even to replace rings, bearings and top end refurb is un economical.
Bigger GM engines get overhauled but the gudgeon pins are held in with snap rings on those so the fall out once snap ring is out.
Also as the Corsa C is so old there are not that many owned by people who could do this level of work them selves now.
Even the Corsa E would be a right off for a garage to overhaul the engine at £50+/hour labour
Thanks for that.
This rebuild is probably costing me about what the car ('05 Holden Combo) would be worth to sell (without the engine problems, as is it'd probably just go to a wrecker for a couple hundred bucks), but we're not interested in selling it. I think we paid about A$2000 for it, plus about A$1500 in repairs to licence it (what you would consider MoT I think). But we've probably already had our $3500 worth of good service out of it already, it's our farm vehicle, carting feed and fencing and such stuff, and giving 14kpl on the road as well (our Landcruiser diesel 4x4 ute gives us 7kpl on a good day). So for what we could buy another secondhand one for, I'm rebuilding this one, we'll have the same vehicle but with a new engine. I can buy secondhand engines for around A$1100.
It's not worn out at 310,000kms, but the rear main seal was leaking into the bell housing and the valve cover was packed full off "coffee foam" indicating a coolant leak, although the compression test was fine. I don't know if it actually blew the head gasket between a coolant and oil gallery but it may have done.
No measureable wear on the rod or main bearings, or the cylinder bores. I measured the bores across the crank and with the crank, 10mm down from the top and 70mm down. All sixteen measurements are 73.385mm to 73.406mm. The ridges are 73.355mm indicating .030mm to .051mm of wear from new. Spec is 73.385mm to 73.415mm. Pistons have some wear through the coating (measuring 72.898mm), and the rings were pretty gummed up. Crank journals are fine. Oil pump is fine. Haven't been able to find specs on the cams but they show some wear and I may replace them. Is there a good set of aftermarket cams available that I should look at?
I didn't price up pistons alone, but a rebuild kit of pistons, wrist pins, rings, head bolts, rod and main bearings, and complete gaskets and seals was A$1250. Timing chain, tensioner, guides, water pump, and fuel pump was another A$375. Rod bolts and main bolts are A$102. That's including about $100 worth of postage.
I dropped the rods off to the mechanic so he can pull the pistons, then I'll clean the rods and take them back to him to install the new pistons. Should have the bottom end finished then so I can get stuck into the head this weekend.
I figured I might as well post a thread here that might help others but if nobody builds them it seems a wasted effort. I particularly love building engines so I don't much worry about the costs of doing it. I did buy a new L34 "crate engine" from Holden about 15 years ago for my stepdaughter, about A$4000 from memory.
