1.8-2.2 engine swap
6.8K views 21 replies 12 participants last post by  corsa sxi ant
#1 ·
morning all.
just a quick question really, does anyone know what the diffrence is between the engine mounts from the corsa c 1.8 z18xe to the 2.2 z22se engine.
the resion i ask is im very tempted with the idea of a 2.2 but wondered if the engine mounts are the same. as i have been offered a 2.2 z22se engine. and i was wondering if i could just run the 1.8 drive shafts too, and what gear box.
thanks ben
#2 ·
im guessing it wouldnt be too difficult
speak to courtenay as they do it anyway
but all that hastle and only 150bhp?
most vx220s are rr'd at less than that standard:eek:
#3 ·
yeah it is some thing diffrent which is what i like but im trying to avoid going for the turbo route as i will looking at running cams with verner pullys, throtle bodys which would be perfect as the inlet is at the front of the engine :D, and alot more.
so i would be looking at running a very safe 230 bhp maybe more.
#8 ·
always wondered why no ones done this conversion yet, seems a good one to me. 150bhp standard (same as a 2.0ltr redtop) and a hell of alot of tuning potential.
this plus the charger kit in a corsa would be fooking immense!
#9 ·
2.2 are ally blocks as well nice and light, don't think there's any weight difference between them and the 1.8s mounts and shafts I recon will either have to be custom or you could be lucky with the 2.2 shafts as the astra and Corsa wideness isnt that different
#12 ·
i've had a look on epc and this is what i've found
front mount same as z20let
right mount same as z18xe astra g
left hydro mount same as z20let
rear mount same as z20let and z18xe.
these are all for astra g.
the z22se is a very capable engine in standard and will go from 0-60 in around 8 seconds which is only a second slower than a standard z20let, but watch out for early engine from 2001 and 2002 as these suffered from doggy tensioners unless your getting it fully rebuilt
#13 ·
Clearly a very useful guy ^ :yes:
#16 ·
sounds yummy to me :yummy:
#20 ·
hard to see 230bhp i would of fort
and are not as light as you would of think, cylinder head ways enough!
will be a very tight squeeze too, not much room in a vectra
ideas nice, but id think about a v6 over a 2.2
yeah true true, might have to follow you down the route on a highly tuned 1.8. cant wait to see yours on the road and going
#22 ·
courtenay sport do a range of tuning options and 245bhp is capable. they start with air box mods with a 10 bhp gain. there not cheap to tune but are alot quicker than people think.
