Diesel do have watse gates tho, u can see the actuator on the cdti, they dont have throtel a buterfly
To be honest i wudent say there a bad thing, ****in up performance is more of a mith, while the valve is open there is less chance of lowing rpm at the turbo compresser turbine as it can flow boost pressure out into the atmosfire, and not b slowed by back pressure meanin after the gear change when the throtel is opened again the turbo is or ready spining frealy and not havein to spool up again,
1 of the biggest reasons y dervs have turbos is tho because exhaust gas temps r around 200 oC iirc cooler than petrol because of compresion ignition ova spark for petrol, as the gasses r cooler the air is more dence, hence bigger boost pressure for such small turbos, T1.5 iirc
oh and dervs arnt ****e :x:lol:
