Help Needed Corsa headlights not working
4.9K views 6 replies 5 participants last post by  andy-v
#1 ·
hi could someone help me i have a corsa 1.2 sxi twinport 06 reg one drivers side headlight dipped beam works but not main beam passenger side nothing works checked fuses with voltmeter all seem OK checked bulbs by attaching positive and negative wires to the battery then to the bulb to see if they light up they do what could the problem be next things to try are the headlight switch could there be a earth wire somewhere not getting a proper connection
#3 ·
The headlamp units share a common earth for the indicator, side light, dip beam and main beam so if any of those are still working you can rule out earth to the unit.
Have you checked the power and earth at the bulb connection of the headlamp unit? It is best to use a test lamp for this as a volt meter puts no load on the circuit so a poor connection/damaged wire may not show up.
#5 ·
Me bought a corsa facelift 2021 1.2 first not working headlight me send to agent where me buy car they change a led light now headlight is direct but indicator make double shift RH have a sign for sensor &seat belts fault &back seats not open the belts (what can we do ? )
