inspection light on
1 reading
1.5K views 18 replies 5 participants last post by  Gazza_DJ
#1 ·
hi peeps
my inspection light is on 1.4sri on a 05 plate the thing is the car as only just done 5k most of wich are motorway miles is this a fault or does it need its first service.
also can i put black plates with silver digits on with out any trouble from the rozzers
#8 ·
there is another way to do it, if its facelift u have to press brake pedal or somethin
#9 ·
found this in the FAQ section
INSP is short for inspection and is the service indicator for your car.
You have two options. you can take it to a garage if you genuinly need a service, but sometimes it just shoes up at the wrong time.
If this is the case, a simple procedure will see it gone
-2003
press button A (center/left side of intrument cluster)
switch ignition on
the display will flash for 2 seconds
keep button A depressed untill '---' appers in the display
release button A
switch ignition off.
2003-
press and hold button A (center/left side of instrument cluter. aprox after 3 seconds the letters 'insp 0' will appear in the display.
continue holding button A, depress the brake pedal and switch the ignition on.
the letters 'insp ---' will start flashing in the display to be replaced after approx 10 seconds with the message 'insp xxxxx m'
release button A, brake pedal and switch off the ignition.
