Cruise control stopped working...
1 reading
26K views 15 replies 7 participants last post by  Shady_Lady
#1 ·
So the cruise control on my 1.8 sri has stopped working.
It was fine a week ago but when I clicked the button to start it earlier it didn't do anything :(
Any idea what could've caused it to stop working?
Will do the pedal test tomorrow to check if there are any fault codes but any easy fixes to avoid going to a
garage?
Could it be related to a pedal or the steering wheel or...? I've no idea
#2 · (Edited)
#3 ·
You have to have pressed the brake pedal at least once since you started the engine for cruise control to engage. You also have to be travelling faster than about 16mph.
If neither of these are the problem, I would start by checking that the clutch pedal makes contact with the switch above it when it is released. If your brake lights are working then it's not a brake switch problem. (Both of these switches are used in cruise control).
#5 ·
Brake light works.
I've tried turning CC on after braking and going beyond 20mph...
Where exactly is the switch on the clutch pedal? How would I get it to work again as I obviously press and de-press on the clutch during driving so how do I solve the problem?
Thanks guys.
#10 ·
Did you use an opcom to find codes or a random code reader/pedal test?
#13 ·
Stalk isn't hard to replace but can be expensive even second hand
Clutch switch is cheap off eBay
Would prob need a op-com to dig deeper & Check if it's still active etc
